Have a pool plumbing pipe that I need to repair. Unfortunately, it goes into concrete and I don't have enough pipe sticking out to save it without cutting off a CPVC ring surrounding the pipe. (Photo below)
The pipe is 2" schedule 40 PVC and the ring is the remainder of a valve that was made from CPVC.
Is there a way to remove the ring safely without destroying the inside PVC pipe?
Thank you!
Thank you!
