Hi guys, I had posted a while back about a dripping frost free faucet at my parents' place but I never was able to really fix it. I wanted to remove the frost free faucet to replace the washer in it, because I'm assuming a bad rubber washer is why it is dripping, but I can't get the bolt off the outside white handle. It is rusted as you can see from the photo. I tried using PB blaster, tapping a hammer on the bolt, and it didn't loosen it enough for me to remove it with a screw driver or socket wrench. The handle turns with the screw, so I have to hold the handle in place with my hand while I try to unscrew the bolt, which makes it even harder to get good torque on the bolt. Basically, I have to hold/turn the faucet clockwise while I try to turn the bolt counter clockwise.
Anyways, I'm assuming I have to remove that bolt if I want to fix the dripping faucet. Can someone give me some advice on what I should try next to remove the bolt? Or if there is a way to skip removing the bolt altogether, that would be fine as well, I just need to fix this dripping faucet. Thanks a bunch for the help
