rustic_philosopher
Active Member
Hey all,
I need some advice from wiser folks than me on setting up some irrigation for my garden and orchard. First let me explain the setup I am working with.
The setup will be trunk and branch and while I will try to minimize junctions there will be somewhere between 3-6 junctions (mix of 90 degree, T and X junctions).
The bits I have questions on are around pex size, run length and ideal pressure tank size. The longest run in the setup will likely be close to 300' I think. I have a temporary line I ran to the orchard for feed a temporary hose hookup and I used 3/4" which worked ok.
So....
Before I start on the trenching, etc I wanted to get expert advice from others.
I deeply appreciate your help on this matter.
- I have a water well as the source of water for the house and ag stuff
- I have a 1000 gallon buried concrete cistern that pull water from the well that is near the garden and orchard area. I have a separate cistern so I can set it up to only pull from the well overnight so both the house and garden dont draw on the well at the same time.
- I have a pressure tank (somewhat small) on the cistern at the moment fed by a submerged pump in the cistern.
So....
- Would it be fine to use 3/4" pex for the main runs and then drop down to 1/2 or 3/8 in the last 10 feet or so to get to the beds (and drip lines) or should I stick with 3/4 throughout.
- Will 3/4" pex over 300' with a moderate number of junctions paired with a reasonable pressure tank satisfy my described needs?
- Are there any advantages to dropping down to a smaller pex size for the final 10-15' branches?
- What size pressure tank should I realistically put in on the cistern since I suspect what I have is too small. I don't know the exact draw down rate since itll be variable with use.
- To try and reduce pressure loss over the distance, are the low pressure loss pex fittings worthwhile?
- What am I not considering?
