Hello, I have a 1-year-old Navien NHB-055 Tankless for hydronic floor heating only, that won't go above 102 deg on the outgoing water, for some reason they installed the "outdoor temperature sensor" inside so in my opinion the unit always thinks it is 70* out and keeps the water at a low temp. Everything I am reading says your water should be between 120- 180 outgoing. Is there any way to override the temperature sensor? I tried unplugging it from the unit but it errors out. I am not even sure if I could run the sensor outside because of how far the unit is from an outside wall and how short the wire is. Or am I wrong about the sensor and something else is going on? Any advice would be super helpful. Thanks a lot
-Jared.
-Jared.
