I have a Navien NCB 240E combi-boiler set up for hydro space heating and domestic hot water (installed 2019) I am having an ongoing issue and can't figure it out. My domestic hot water side is set to around 125 F. When I turn on a faucet to call for hot water, the flow rate is 0.6 GPM. The boiler will heat up to 125-130 F temp and hold for a few minutes. Then the temp starts dropping, and I hear the boiler trying to re-ignite as if it's trying to heat up again but it goes into a cycle and is unable to heat. Eventually the temp drops because the unit cannot fire up again and the water starts cooling and then its very cold water at the faucet. The boiler will continue this cycling when calling for hot water and eventually after a few minutes sometimes it will work and start to heat and sometimes it will stay in this loop. The machine shows no error codes.
Video of the issue, listen to the audio - Navien NCB 240E Ignite Issue
I reached out to Navien and they said to contact a local plumber who is an authorized tech, which I have done, just waiting on them to firm up an appointment. Wondering if anyone else has encountered this.
