name this valve(?)
Jonathan Ewald
Oct 24, 2018
Western MA
Hello all! Amateur question:
What are these?
I have a boiler heating system, and these are at the front end of two of my heating water loops. It looks like a brass valve, but there's no handle. As you can see, there is a screwdriver-turned bolt. Is this correct? Or is the nuts-looking part the part to turn?
The house was built (and presumably, so was the heating system) in 2001.
I want to know what this is before I start messing with them. Are they pressure valves?Ball valves? Some other kind of turn-off valve?
What are these used for? Are they specific to a boiler heating system?
Nobody at a Home Depot has ever seen these things before.
Thank you very much in advance.
    381.5 KB
    331 KB
They are used for isolating a Zone when purging air out of your boiler system just a simple valve quarter turn left or right stops the flow
Thank you very much for your quick (!!!) response! I assume that the flow is with the line ie if the screwdriver line is perpendicular to the pipe, the pipe is blocked.
Thanks again!
Are those coin valves? How has nobody at Home Depot seen them? Most hot water heater drains use that style of valve.
