I just finished my first ever soldering job. My hot water tank ate itself so I installed a new Rinnai tankless one. This required a reconfiguration of existing piping. I wanted to do it right, so I used solder joints versus push-on fittings.
I practiced on a few scraps until it looked like I had it right. But my questions are:
1) None of my almost 20 joints are leaking. If they are not leaking now, can they start at some point? The tank is in a closet and it could be months before anyone would notice a pinhole leak.
I was concerned about a couple of joints. For some reason, the HOT line would not stopping dripping water. I opened all HOT taps to release suction and even after overnight if you jiggled the pipe, a couple of drops of water would come out. Did my best to dry it up, but there were still a few drips. I did use MAPP and so far there are no leaks on it.
2) How long until the Flux taste goes away. I used Oatey No. 95. And probably too much solder.
I did take a nice long hot shower last night and didn't run out of hot water, so that is a big plus.
Thanks,
Chris
Thanks,
Chris
