Jonathan S
- Joined
- Mar 7, 2024
- Messages
- 17
- Reaction score
- 0
Hi,
I have a strange musty smell in my new shower. To me it smells like musty water. At first we thought the smell was coming from the drain. We have a Studor valve installed in a small "pony" 1/2 wall between our tub and shower. We had the Studor valve replaced but the problem persists. Also, I tried just pooring hot water down the drain and didn't really smell the musty smell. I've tried cleaning the floor tile with a scrub brush. The smell kind of smells like a musty chalky smell.
It comes and goes. Sometimes it is very strong.
I also tried removing the shower head and letting water run from the pipe. As far as I can tell the smell isn't coming directly from the water. I've had a plumber come out and check the shower valve and there are no leaks there.
It is frustrating because I can not identify where the smell is coming from exactly. My next step is going to be to clean all the tile and ceiling with a mild detergent to see if it something with the water interacting with a surface.
Any other ideas?
Is this a venting problem?? Is the Studor valve just too enclosed and doesn't have enough air to work properly?
How do I identify the true source of the smell? Why does it come and go?
Thanks in advance,
Jonathan
Any other ideas?
Thanks in advance,
Jonathan
