ddaavviidd
Hello all,
I am trying to get more water pressure. Last week I had an episode where pressure dropped significantly, and I think I found the problem; the pressure tank was almost empty of air. I brought it back to around 30psi empty which gives about 40psi when full of water, which is what it says on the sticker.
But while I was at it, I tried to increase my water pressure (coming from a well about 150' from the house, 180' deep, 600gallons per hour according to the ex-owner of the house). The submersible pump is 8 years old. My pressure only reaches 24psi, and as soon as we use water, it goes down to 20psi. I spent significant time changing settings on the 2 adjustments crews, which either made it worst of remained the same. I am trying my best to solve this without calling a plumber, but would be ready to do so if it means I'd get a stronger shower! Is there a procedure to troubleshoot the issue, starting with the pump and all the way to the adjustment box?
Pressure tank dates from 2006 (according to the sticker) so I assume the box too. Thanks for any help or suggestion you can provide!
