Moen Shower mixer stuck
Dook787
Mar 15, 2023
14
Charleston, SC
We’re starting the process of redoing our shower and I am unable to remove the shower mixer. All the screws were basically stuck, had to drill out the set screw for the handle but was able to remove it. Now I am to this brass piece, I have removed the screw in the center but it will not budge. I’m unable to get the face plate off without removing it. Do I need like a puller or something? Am I missing something? Any help would be greatly appreciated. Thanks in advance! 13321CBA-70F2-4765-8634-8739DA9DB74B.jpeg
There is a normal Moen cartridge under there. If screw is gon, then, yes, a puller.
Get all the new parts together
Turn water off
Break that adapter off.
Remove trim/escutcheon plate
Pull the copper clip that retains the cartridge.
Pull the cartridge.
Install new cartridge
Replace copper clip
Turn water back on
Reinstall trim/escutcheon plate
Install handle adapter
Install handle.
Turn water off
Pull the cartridge.
Replace copper clip
Turn water back on
Install handle.
Thank you! So what I’m looking at there is a handle adapter? Do you have any recommendations on how I’d go about breaking it? As far as the cartridge, do you think I’d just be able to pull it out after the handle adapter is removed? Or you think I might need a puller for the cartridge? Thanks again
Yes, that’s a handle adapter.
You can break it off the stem by using channelock pliers and rocking back and forth. Use as much force as necessary until it comes off or breaks.
Alternatively you could cut it off with a grinder or dremel tool. Safety glasses.
You may need a puller, you may not. There’s no way for me to know. Remember to turn water off first and remove the retention clip.
Sounds good, I guess I’ll get to cutting then. Thank you very much for the input, I appreciate it!
