RustyShackleford
Seeking help with my bathroom lavatory sink, a Moen one-piece control (a knob you pull out for flow, rotate for temperature). No cold water comes out. When I rotate it fully counter-clockwise, I get full hot flow. As I rotate it clockwise, the hot flow reduces as it should, but no cold water is added to the mix, so when it's fully clockwise, there is no flow at all. It's as though the cold-water supply valve was turned off.
I guess it must be in the faucet itself (as a blockage in the cold-water line seems unlikely). Is this a common failure mode for these faucets ? (Mine is about 27 years old). Should I just replace it ? Thanks much !
P.S. It's been very cold here (like almost everywhere), but my "encapsulated" crawlspace is staying at 60 degrees or so, and all the other faucets work fine, so I think it's just coincidence.
