Ok, I’m gonna share a trade secret with you. Follow this procedure for a leak free threaded connection.
1. Undo all leaky connections and thoroughly clean threads with the brush;
2. Throw away your white Teflon tape or keep it for irrigation purposes;
3. Go to big box store and get Blue Monster tape or grey oatey, your choice;
4. Wrap, three and only three wraps of mentioned tape around your threads clockwise only if using plastic with metal, plastic on plastic - only thread seal only, no tape!!!
5. Secret: Start running your fingernail at the start of your threads clockwise, pushing all the air out between tape and threads (do not tear the tape, otherwise you will have to start from scratch;
6. Apply thread sealant;
7. Tighten lightly plus 2/5 turns, check for leaks. Continue with singular 1/4 turns until leak stops.
*Please follow exact procedure. If it’ll not help, you have two options:
1. Replace plastic adapter with brass one; or
2. Use blue sealant.
