GurneyHalleck
My 1/2 HP gould pump died so i went to lowes and got a 1/2HP replacement. Hooked it up and it ran fine except...water pressure only reached 27 psi, well below the 20/40 switch rating. The old pump never had pressure problems, so thinking it was a power problem, i got a 3/4HP pump and hooked it up and voila: the same 27psi reading, and the pump running constantly. As an aside, I had the pressure tank originally at 18psi, under which conditions the pump only reached 20psi. cranking up the pressure tank to 38psi got it to reach 40psi in the line and cut the pump off, but once it started running it went right back to the 27 psi reading. I know I have a miniscule leak in my kitchen faucet, but again, this never kept the gould from reaching 40psi. Should I just give up and accept 27psi (and set the pressure switch accordingly) or could this tiny drip leak actually be causing my problem?
