Moose151
The water pressure in my house was never spectacular, we have lived here since 2019, but it seems to have gotten worse over the past 6 months or so. We have a standard deep well dug in 2000. The issue is causing my dishwasher on the first floor and washing machine on the second floor to not function properly and also the second floor showers and exterior hose pressures are very weak.
I first noticed that the pressure gauge wasn't properly registering PSI so I adjusted the 40/60 pressure switch to increase the pressure in the system. This made a huge improvement for 24 hours until I replaced the pressure gauge and pressure release valve and the pressure gauge was up over 80 psi which obviously is bad for the system. I adjusted the switch back to the proper 40/60 range and the water pressure went back to being poor.
Then I replaced the pressure switch thinking that perhaps that was the issue. I installed a new 40/60 pressure switch but nothing about the water pressure has changed. I then thought perhaps the bladder in my tank was blown so I checked to see if water would come out of the valve at the top of the tank but it did not. I then checked the pressure of the bladder and found it to be 40 psi with the system at rest.
I've run out of ideas here and apart from calling a professional I'm not sure what is left to do. It doesn't seem like theres anything wrong with the tank and I replaced all of the other parts as well as regularly changing my water filter.
Any idea's what my issue might be would be greatly appreciated.
Moose
Moose
