looking for code compliance
Dec 12, 2024
11
98360
Would like to check if these two options are code compliant and if its even necessary to ven the bathroom sink condidering it will be draining to a 45 to the shower which will be connected to a roof vent that is shared with the kitchen sink (kitcheen sink also has a mechanical vent)
Those air valves just need to be accessible, either outside in the cabinet or access panel when its in the wall cavity. I don't want to say anything about the pipework but wouldn't install it like that in my house but it should still work fine.
The second sketch shows the P-trap connecting to a combo wye which is not to code. That fitting needs to be a Sanitary tee. I assume you are putting the AAV in the attic because you don't want to put an access box in the wall. I think I would rather have the AAV under the sink in the trap arm like the first sketch as opposed to in the attic. If you did that, you could then use a combo fitting or a Sanitary tee for that drain connection to the vertical drain line.
Can I use a street 90 in the wall with a 2"x 1 1/2" reducer or does the wall 90 have to be long turn
your not going to hurt my feelings this is literally my first plumbing job just looking for the best way to install this
With the AAV under the sink, you can use a regular 1/4 bend, i.e. 90. If you can find the following item, it would be the easiest to use. Otherwise, you can use a 1 1/2" or 2" 90 with the reducer in the appropriate place.
