I read a lot about Liberty sewage ejector pumps and hear they are very good. My plumber agrees. He showed me which one he would be installing P382LE41. I believe it simply pumps out up to 2" solids. I'm sure the pump is fine, but after doing further research on their pumps, they also sell grinder pump models which claim to annihilate feminine products and rags and such. I will have tennants, so this is a plus for me and I don't mind spending the extra money for the grinder model to avoid any future problems.
However, I spoke to Liberty pumps on email and they recommended something similar to what the plumber wanted to use. I asked them about the grinder model and they said they wouldnt recommend it because it may cause problems with my septic system if I'm pumping to a septic tank.
The way my sewage system is designed is, all the waste goes to my septic tank(solids) then as the septic tank fills up, the liquid will overflow to a cesspool.
1) I dont see why a grinder pump would cause issues and maybe you guys could shed some light on this and what type of problems this would cause verse the regular model. If anything, I thought it would help the septic system with everything being grinded up. The grinder model Im referring to is the P382XPRG101/A2
2) If I did go for the grinder model instead, they either come in 115v or 230v. Any reason why I should choose the higher voltage model over the other or vice versa?
Thanks.
Thanks.
