Legionnaires prevents in vacation home.....
rs4duke
Nov 19, 2015
9
Hi,
I am doing a design for a large residential vacation home for a client. This home will only be used for certain times of the year. How can I prevent legionnaires from growing in the pipe system when the home is unoccupied for periods of time when temperatures are in the optimum range for legionnaires to growth.
Thank you,
Rob
i would suggest keeping the residence winterised when not in use.
legionnaires only grows in stagnant water, I would suggest to add a cup of antifreeze to all ptraps
to keep them from drying out and freezing.
make sure you have no any standing water in, whirlpools,hot tubs,washing machines and dishwashers
no standing water, no legionnaires
if you do have standing water, add a cap full of bleach
inspect ac equipment drain pans and drains for proper drain pitch
Thank you Frodo, what about the stagnant water that would be in the piping system when not in use? Does this need to be purged out?
Appreciate it!!
yes, when you winterise a home, you blow the lines out
empty water heater
open all valves
using compressed air, blow all lines out
anti freeze the ptraps
blow out sprinkler system
turn off gas, turn off breakers
I had clients in Telleuride who were only there for a month out of the year.
they would fax me a grocery list,
I would stock the home, turn on water, start the heater.
turn key for them, when they left. i would winterize the home
remove any perishables.
have a cleaning co, clean the place,
nice little job. very easy, very lucrative
