Hello. I have a leaking sillcock made by BK Mueller. I heard that if you take the stem out and seal the weep hole, it will stop leaking. I removed the inner stem and I can not remove the screw on the stem (see picture C, screw is not visible in picture).
I dont mind buying a new stem (BK Mueller 889-558 8 Inch Repair Kit-discontinued) but I can also not remove the chrome fittings (see picture B), because the non chrome fitting (see picture A) is "stuck". The chrome fittings can rotate but not move up or down.
I would replace the whole sillcock but when turning the whole assembly slightly, it also rotates. I think there is a copper to PVC connection back there but I can not get to it. Any suggestions? Thank you!!!!.
