Good day all,
I am new to Plumbing Forum, having joined to get some answers or thoughts on an issue I am encountering in my basement laundry room.
To preface my question, I am not a plumber and have zero plumbing experience, so please bear with me.
Anyway, I'll get right to it...
The attached picture (Slide1) shows the plumbing behind my washing machine in the basement. The part I have circled (closeup in Slide2) has always gurgled and spit a bit of water when the tub is being filled, however, as of recently it has been doing this while the machine is off and no other tap is running in the house. Water is coming out of the two little vents (one in the back that can't be seen) and leaking onto the basement floor. It even does this if I turn off the tap to the washer. I can see water draining through the bottom pex pipe, but it doesn't appear to be coming from the main line and I can't tell if it is coming from the washer side.
What is that piece? and what purpose does it serve? Is it an air vent or air gap?
Secondly, why would it be draining if water is not running?
I do not hear gurgling noises in any toilets or other sinks in the house.
Thank You
Thank You
