MPgwinnett
I don't see pvc in the table.... Just saying #voletl
I don't care what code you go by but the code that I am under PVC is approved for the discharge pipe you can go to any supply house or Home Depot or Lowes and pick up a premade discharge pipe made of PVC
Just because the pre-fabricated PCV drain pipe is sold by no means makes it within code.
Think of it this way-
Your wife is standing close to the WH doing laundry. For some unexplained reason, the relief valve trips, the hot exhaust water melts the non code compliant PVC and scalds her while standing there.
Does this help you understand? ...
There is no argument, PCV is not approved.
Not arguing here-
Most likely there would be no complete disintegration. Maybe just a pinhole or two. Water temp @ 210F and then hitting atmosphere, don't you think there might possibly be a scalding incident possible not to mention water damage?
Just because HOME DESPORADO sells them and you see them installed frequently doesn't make them code (or safety) compliant.
ADDENDUM (Fr For Addition)-
PVC has a temp rating of 140F. The T&P releases at 210F (WH Internal Water Temp).
CPVC has a temp rating of 200F. I remember reading some years ago discussions of the approval of CPVC for the discharge pipe. After all of this discussion, think I will personally stick with copper.
The 140 F rating is based on continual use.
Those pre made sticks they sell at home depot are what come with some water heaters (at least around here) the manufacturer thinks its fine then I'm sure they don't feel like taking the fall if those were likely to fail.
stevemachine continues said:But i will agree i only do copper. Just saying that pvc wouldn't fail unless that prv was constantly dripping. But if it was a one time thing guaranteed it holds up. If it was a weekly occurrence then i would agree that it will fail eventually. If it happens more than once there's a more serious issue which needs to be dealt with.
GOOD POINT!
It might be all the panty wadding is just disinformation. I searched HOME DESPORADO for details and came up with this_
Everbilt 3/4 in. NPT x 63 in. Polypropylene Side-Mount Runoff Tube
Maybe it is not PVC, but polypropylene, which is compliant I think (cannot make out code book page photo- short eyeballs). Hopefully the plumber realized this where we didn't.
OK... Hopefully everyone can now just raise up a bit and pull their panties out. I'll buy first round...
I agree, expansion tanks are the new "IN" thing and are not needed 95% of the time
By the way... Found a service sticker on the heater. These are the guys that performed this installation:
http://www.reliableheatsny.com
During this period, unknowingly to us, he filed a claim with AO Smith regarding our WH, took off the serial, and collected the money
4. My wife and I discovered in 2014 that Al's Plumbing was on the local news identified as unlicensed crooks: plumbinghttp://abclocal.go.com/story?section=news/7_on_your_side&id=9154553
