Aggie83
My house is about one year old and they installed Kohler 360 toilets. Everything was great at first, then they started filling slowly. The water comes out of the wall valve at a nice pressure! Very hard well water, ,so we had a softener installed. I replaced the toilet fill valve with Fluidmaster and that seemed to work. Now the siphon jet does not seem to send much water... very weak. done vinegar soak with no joy. The tank and bowl fill at an appropriate rate.
Could this possibly be a partially clogged drain? Nothing else is backing up, but the kitchen and laundry are 35 feet away and the shower goes in after the toilets. Not real happy with the plumber the home builder used...
