Got a question on a plumbing issue. My kitchen sink isn't draining properly. It's one sink with a garbage disposal. When I run water it seems to not go down the drain, I'll turn the garbage disposal on, it will drain, but then a little water comes back in the sink. I took the drains out under the sink, ran a snake through them all, even like 20 feet into the wall, nothing seems to be clogging it. I also put baking soda and vinegar in the sink, let that sit for 15 minutes then dumped boiling water down. Didn't work. Anything else I can try on my own?
The blades for the garbage disposal are turning, and I disconnected the pipe from the garbage disposal, couldn't find anything clogged in there.
Thank you for the help.
