Kitchen sink waste line issue
gablake
Jul 23, 2012
I just moved into a townhome with myriad plumbing issues, and this is my first of, I'm sure, many posts. The current problem I'm having trouble with is this:
The kitchen sink is up against an exterior wall and (I thought) was draining just fine. Then yesterday while my wife was using the sink and I was outside I heard water splashing on the ground. There is an open (female threaded) pipe just opposite the sink's drain and all of the water was pouring out into the garden. I got out my drain snake and removed some clogs (up to a depth of about 4 feet), but the water still pours straight out this pipe. The townhome next to mine has the same pipe, but theirs is capped off.
My questions are:
What is this pipe for?
If the water is pouring out so easily, is this indicative of a larger waste line issue?
The opening looks like aprox 2" diameter, is there an industry standard cap for this?
The open line is just what you used ir for. It's a clean out and it should be plugged. What is going on is the line has a stoppage and needs to be snaked. You need the proper sized power machine to do the job. Consider hiring a plumber to take care of this for you. There are many plumbing repairs that most home owners can handle but this is not one of them.
John
So you think there's a doosy of a clog down the line somewhere? I was kind of hoping that the water was just following a path of least resistance and going out the uncapped clean-out.
-Graham
Can't say for sure what kind of stoppage you have but most can be cleared in less the a 1/2 hr. with the right equipment. Even more so seeing you have a clean out that is easy to get at.
John
Thanks for the advice, Johnjh2o! Problem solved.
For future readers: I got a "Mr. Rooter" guy out here for a free inspection and he bid $230 for the job. I said thanks but I'm going to shop around, and almost immediately he dropped the price to $135.
That's how all the company's with ROOTER in there name do business. Doesn't give you a very good feeling about any company that first try's to make a score on you. Stay away from company's with ROOTER in there name.
John
