Kitchen Sink Hot Water Low Pressure
toddhmurphy
Jun 13, 2017
I replaced my undersink water filter which runs off of my cold water. For replacement I turned off both the hot water and cold water valves under the sink. When I turned the water back on I lost all pressure in the hot water.
I tested all other hot water faucets in the house and all are OK. I tested the aerator, not clogged OK. I disconnected the hot water connect from under the sink to the faucet and turned the water on and nothing came out. Which leads me to believe it is not a problem from under the sink to the faucet.
What should I do next?
Thanks!
Thanks for the response, John. I took the hot water pipe valve off from under the sink, a little sediment came out but the pressure is still low.
What next?
