Mervmaster
I've installed a new countertop and sink. The new sink is slightly deeper than the old, causing my p trap outlet to be at or below the level of my waste line port.
I have access to the crawlspace, and I'd like to send the kitchen drain line through the floor, and have it join the vent line a few feet after it does now.
This will cause the waste line to run vertically through the floor after the p trap.
Is there any reason a shouldn't have the line running vertically?
I know 1/4" per foot is the correct pitch, and more than 1/2"-45° is bad.
Is 90° acceptable? Will is cause a siphon, or a flooded condition at the elbow where vertical turns back to horizontal?
Thanks. I can't find anywhere that says this is OK, nor anything that says it isn't.
