Glad to help you Jacob. First off, make sure you correctly spell toilets and foreign. That will certainly help your grade!
Clogs (or blockages) occur for numerous reasons. Many occur because hair can snag the slight imperfections where the plumbing is connected, which will compound itself as other sewage passes through it.
Other blockages occur similar to the entrance to a business. The doors can easily handle one person at a time, but when 10 people try to enter the door at the same time, the doorway will just be too small and everyone gets backed up.
Another reason blockages occur (especially kitchen sinks) is when hot grease is poured into a cold sink. It solidifies immediately, causing blockages.
Lastly, many sewer pipes are penetrated by roots from bushes and trees, which are searching for a water source. Once the root enters the pipe, they get bigger to carry more water and nutrients and will eventually completely block the line.
I hope these help a bit, and I am sure many professionals here will provide you more reasons for blockages.
