I recently posted about a slow leak and was able to fix it by applying Leslie's Pool & Spa Lube between the cap and the filter housing. Unfortunately I found another leak during that process.
There is a PVC pipe, about 2.5" in diameter that connects to another pipe using, for lack of a better term, a "twist on" seal. I tried my best to get it loose, but it is stuck on there, and there is actually no room to separate the pipes even if I got it loose.
So there is a slow leak coming out of this connection. I'm wondering if anyone knows of some kind of sealant/glue/epoxy/etc. that could be applied to the outside of the pipe to stop a slow leak?
