Is there a better way to tie in the Kitchen Sink?
flannag
Jan 5, 2012
7
I'm not allowed to wet vent in Kentucky. Also this is an install in a log cabin so I am trying to minimize the amount of vent pipes I have. TIA
The way you show the kitchen tying into the drain is above the lavatory drain, so depending on definitions in Kentucky code, that could be considered a wet vent. It could be done under FL code, but might not be under your code. It might need to be tied in underneath the branch arm for the lavatory. Or you could add another stack in the wall just for the kitchen.
I also see a problem with the shower vent. The section of piping for the branch off to the Ptrap to the wall where the vent turns upward is a flat dry vent, disallowed by most codes. If the pipe passes underneath a wall on the way to the Ptrap, you could turn a vent up in that wall. Otherwise, you need to run to the wall, turn up, then put a tee on the vertical to run back to the Ptrap.
beyond the "shower vent" is another ptrap for the washer that will share this vent. Will that wash that vent or does it need to be washed every time the shower is used?
Like Phishfood said Tye in under lav sink with a wye.
If you don't have the room and you can go under the floor you can tye in on horizontal line with a wye also
Not sure what you mean. A vent is always dry unless it is wet vented, that meaning the vent is shared with a drain.
shower drain should be similar to this. If the Santee is lying flat with the vent horzontal It can foul up and fail.
I was planning on sharing the vent between the washer and shower. I didn't know if a vent needed to be washed every time it was being used by a fixture unit or if a fixture distant to the vent could wash it "on occasion".
If the washing machine ran down the line that is venting the shower Ptrap, that would be a wet vent, at least under FL code.
Even if it weren't a wet vent, it is NEVER a good idea to drain a washing machine down another fixture's vent. It can blow the water out of a trap, and also suds can back up out of the other trap.
Edit: Also, to add to my first post, make sure that the toilet vent rises at least 6" above the rim of the toilet before it turns horizontal.
Very interesting. So...I could/should vent the washer with the vent currently drawn. Then, I would have to find a way to vent the shower. How do I vent to the wall between the shower and washer then back to the branch or main without having a bunch of hard turns?
If using the vent for shower and washer makes it a wet vent for the shower then why doesn't the vent form the kitchen sink make a wet vent when it shares a branch?
If you run the kitchen sink as Mr. David drew it in red in post #4, then there is no wet vent. The pipe below the arm to the lavatory drain is not a vent, it is a drain. Since the kitchen drain pipe ties into the drain, there is no wet vent. If you look at your original drawing, the lavatory arm is tied in, and the pipe above that is a vent, with the kitchen drain tied into it.
On the shower, run straight at the washer vent as you have it drawn. Before you get to the vent, add a wye into the drain line, and off of that wye turn another stack up in the shower wall. On that stack, catch the shower as Mr. David illustrated in red in post #6.
So far thanks for everything, great forum, great posters.
Clarifying: The original picture I drew has a vent ascending from behind the lavatory sink. With that vent in place would the drain entry for the kitchen sink I drew still be considered a wet vent or was the original drawing ok? I totally see why your's is easier though.
just tie it into the vent. if anything the inspector is gonna call out the vent in the ponywall. your vents need to be at least 34'' before you turn horizontal.
The Auto washer p-trap should be above the floor not below it
Yes, that should work. Probably just the way it looks in the drawing, but you don't want the kitchen drain stack to attach to the horizontal vent pipe they pass by eachother in the wall.
awesome, I'm learning. Is there any way to join the 2" washer and 2" shower so they join the 3" main branch together?
Yes, there is. Come off of the main line with a single branch, and then wye off before you get to the wall so that you have two drain lines running to the wall.
