A couple of years ago I had my well pump replaced. I had someone replace it for me. Then on my own, I replaced the pressure tank, pressure switch and one way valve. My well and pressure tank are located in a pit that is in a small building outside of the house. After I had all of these things replaced, I will occasionally loose water pressure. Could be a couple of times a week. Could only happen once every 2 or 3 months. Very erratic. I replaced the pressure switch again, thinking the new one was bad. It didn’t help. I have lowered the pressure in my pressure tank thinking it was too high. When I do loose pressure, I go to my breaker panel and turn the breaker off that feeds the “well house”. I then turn the breaker back on and my water pressure is restored. For some reason, the pressure switch will not kick on when the pressure drops. Tripping the breaker will make it kick on and start working again for a time. Any thoughts on what I’m overlooking here? Thank you.
