Interesting new part in Fluidmaster
NWTennesseean
Nov 4, 2019
15
Northwest Tennessee
I noticed a new part in a Fluidmaster that I recently purchased. I've verified it was not in earlier versions of the product. I wonder what its purpose is. It appears to force the incoming water to travel thru a circling channel before it reached the point beyond the part. Note, it can be removed easily by pulling it out with some needle-nose pliers; it is held in by friction fit alone. You can see it in the lower tubing of the Fluidmaster. At first I thought it was a manufacturing mistake, but as noted it appears to have some function to enhance the product.
It slows down the fill to make it quieter. It’s a flow restrictor. I remove them.
I believe it is also designed to stop inserting the tubing so far down the tube that you create a "siphon out" affect.
No, that’s the refill clip you’re talking about.
The part pictured is found inside the water inlet.
