Jacob4Jesus
Helo Forum,
I recently purchased a Reverse Osmosis water filter. While trying to install it the instructions assume that there is a flexible line leading from the sink to the water shutoff valve.
The instructions mention that if the line is rigid plastic, which mine is, then it will need to be installed using a compression fitting and that that process is not otherwise included in the manual.
I assume that I am going to need to cut the water line to make room for their T connector. What I don't know is:
--Jacob
- How much line should I cut and what margin of error is there?
- How can I cut it without damaging the remaining portion?
- When I go to buy a compression fitting, which one do I buy?
--Jacob
