Mike Green
I have a 2500 ft^3 basement utility room housing 2 hvac units and 2 heat pump water heaters. I am adding an additional washer/dryer to the room. I am considering venting the electric dryer directly into the utility room with the idea that the warmer moist air will allow the heat pumps to operate more efficiently. The humidity has dropped to the point the dehumidifier in there no longer turns on (set at 50). Is it even worth the effort/risk or should I just vent the dryer to the exterior of the home?
