Hello,
I have a leaky shower head and am 99% sure it is the hot water cartridge that is causing the issue. I had a plumber "rebuild" the cartridge, but that fix only held for a couple months. Its time to just replace the cartridge.
I am confident I can remove the cartridge, take it to a plumbing supply store, and then install the new cartridge. However, the issue is that there is no local shut-off to the shower. So if I mess up, for whatever reason, I won't be able to turn on water to the entire house. Is there some sort of "plug" I can buy and stick in place of the hot water cartridge if it all goes wrong or if I have to special order the cartridge?
Nobody can tell what kind of cartridge I need by looking at this picture, can you? The house was built in 1931 - I believe the plumbing is original (galvanized steel).
Thanks for your help.
-Chris
-Chris
