Plumbum1234
You are getting close but tying into your cold-water line there is still wrong. You need to tie the warm water return to the cold-water inlet of the water heater below the valve on the water heater. You should also install a check valve in the cold-water inlet to the water heater above that tie-in point so you don't pump warm water backwards into the cold-water line.
I didn't look up the pump, but SHEPLMBR said these pumps are for well tanks. And as most hot water circulating pumps are line mounted and do not need to be mounted on a joist with a vibration pad, I'm thinking this isn't the correct pump.
Below is closer to what I think you're saying (I hope).
There is a check valve built into the pump (I know this doesn't address you question - just an fyi).
Since the pump is such low flow and it should be creating a slight negative pressure on the water heater, wouldn't it be hard for it to overcome the force of the cold-water supply and therefore a check valve isn't absolutely necessary?
She was referring to the tee I was originally suggesting for the tank drain (not going down this route). This is an AquaMotion, Model AMH3K-7 pump which was originally designed to go under a sink, but I am repurposing it since I already have it and a dedicated return line. I also asked the OEM if this is acceptable, and they said yes.
