Sorry for the horrible pictures. Told a friend i can replace the valves in the leaking faucets. Not seeing any type of brand name. Located in Southern California if that helps determine possible brands.
I think it's also t+s but would have to see the stemsThe first pic, that’s T&S brand.
Not sure about the pre-rinse faucet. Maybe Krowne.
I understand and I also assure you it’s T&S. I work on them couple times a month.I think it's also t+s but would have to see the stems
The second pic.Sorry for the horrible pictures. Told a friend i can replace the valves in the leaking faucets. Not seeing any type of brand name. Located in Southern California if that helps determine possible brands.
Both hot and cold faucets have to be left on with the OUTLET off for crossover to occur.Very imformative i was wondering about that check valve. Could this be the reason they dont get hot water to some of the sinks? Its a tankless heater. She had a guy come out to check it and said the water heater is fine. They have to turn on mulitple faucets and let them run for awhile before the water comes out hot.
I dont understant that part. If they only open the hot valve, how can cold water be mixing in? Is the cold water check valve actually stuck open even though the handle is closed?
