If the gas tankless water heater is set at 125 degrees and the hot water runs through 200' of 3/4" pex and 10' of 1/2" pex before it gets to the faucet, what temperature would you expect at the faucet?
The temperature in the attic where the hot pex line is routed is 80 degrees. There are some 1/2" branches that route to other faucets along the way.
How long would it take for max temp hot water to get to the faucet from the tankless?
Would I expect hot water within a few seconds at the faucet if there is a recirculation line/pump installed?
Thanks in advance
Thanks in advance
