To my knowledge, you can only get legionaries thru airborne bacteria or inhaling a mist, such as showering in it. I don't think it will absorb thru the skin
Legionnaires' disease is a type of pneumonia caused by bacteria. You usually get it by breathing in mist from water that contains the bacteria. The mist may come from hot tubs, showers, or air-conditioning units for large buildings. The bacteria don't spread from person to person.
Symptoms of Legionnaires' disease include high fever, chills, a cough, and sometimes muscle aches and headaches. Other types of pneumonia have similar symptoms. You will probably need a chest x-ray to diagnose the pneumonia. Lab tests can detect the specific bacteria that cause Legionnaires' disease.
Most people exposed to the bacteria do not become sick. You are more likely to get sick if you
Are older than 50
Smoke
Have a chronic lung disease
Have a weak immune system
Legionnaires' disease is serious and can be life-threatening. However, most people recover with antibiotic treatment.
Thought I was done here. Then considered this update.
I went to the health department and got a kit only find out before I used it that they would only test well water.
So I took the kit back but found a state department that will test drinking water free. She talked to her "people" ... I think she said the guys that work for the state maintenance and they said they keep the state's WHs at 115 to 125 to be safe and they recommended that I flush it every few months if I could.
I considered the statement above that on a gas WH when that thing does heat up from the bottom there is some serious heat going on there. Is there anything to that?
That gas flame must get pretty hot keeping it at 125F .... No? Also if the state came and tested my drinking water I doubt they let any hot water stay in the line. (one said above that if you have a one faucet config there is cross contamination. I do)
They'd probably run the cold water for 5 minutes before they draw a sample? Anyone have any suggestions how I could flush it.
There is no drain in the basement but the washer drain. Spout is about 3feet? plus or minus high and 10 feet away to the washer.
Of course WH drain is at the bottom. Do you turn off the gas? Do you let the tank cool down? Do you flush just the bottom or the complete tank? How about if I ran all the hot water into the washer after flushing a bit out of the bottom and completely replaced with fresh water behind it? Thanks! ":-Dx
turn off the gas
hook a hose to the drain, run it to the outdoors/floor drain
turn off the valve on top of the wh, open your washing machine hot water faucet [disconnect the washr hose]
empty the w/h, turn the valve to the w/h on let it run for an hour
close drain valve, fill heater, after w/h is full close washer valve
you will need to go online, fined a inline garden hose pump
Yes, I totally get that now. You know, sometimes we know what we mean but communicating it the very first time the person at the other end has to visualize. I do see what you mean. I actually was wondering about that "siphoning" issue a post or two back at your original post. I'll have to work on getting that water out of the basement or at least into the washer. I can then let the washer pump the water out on a spin cycle. hmmm ... but how to get it from the tank into the washer ....Some would probably move by gravity but that would only be good for about 1/3 the tank. I guess I could have a solo bucket brigade. It's not that large of a tank. Standard I guess. About 4' tall.
Do I still need to tell you what state I'm in? lol A state of "I don't know ... " haha!
Just my 2 cents here if you haven't flushed your water heater since the late nineties I wouldn't bother doing it now.
Lots of talk here about flushing WH's. I have never heard anyone but a plumber ever talk about doing that, so I suspect most people never do. My gas WH is going on 30 years without a flush.The water was like the weakest tea at first and then cleared up pretty much. Some calcium showed at the end. . . . . The water was cleaner than I've seen some dirty wash loads!! So I guess after 20 years that's a good point for the town water.
Where have I gone wrong in my analysis?
LOL! I'm done. I don't see where after 20 years anything that significant showed. The water was like the weakest tea at first and then cleared up pretty much. Some calcium showed at the end. I'm never used the pump and I'm going right back and return it for my $90. I just put the water in the washer and let it pump up. The water was cleaner than I've seen some dirty wash loads!! So I guess after 20 years that's a good point for the town water. Have to tell my cuzin. He's been the town manager for the last 15 or more years. So uneventful and whether I did any good or not I do not know. ":-\\
