Not necessarily a booster pump. The recirculating pump just needs to be rated/ spec'd out properly.
A hot water recirc pump doesn't pump the water up 11 stories. It cups the water and moves it into the water heater. The return line is coming down from near the top of the system. So the water coming down the system is replace with the water going up the main distribution system.
As for the overall available pressure near the upper part of the system, it will be dependent on how the system was designed.
