Hot water debris
tnelson55
Apr 7, 2015
Some brown smooth flat plastic-like debris has appeared in my hot water line. It has been plugging my faucets and shower heads thus slowing the water flow. I have an Amtrol Boilermate and was wondering if it could be some inner lining that has deteriorated. I've never seen hard-water mineral deposits like this before. I have done repeated flushes on my lines at a number of the faucets. Any thoughts of what it could be and the possible fix?
disconnect the piping on the cold side of your hot water heater. take the nipple out
stick your index finger inside the hole, bend your finger,,,pull up.
LOL..that how I do it,,a plastic tube will come out. it is about 3' long. replace
that tube,,incidentally, is the only difference between hot and cold...if you move it to the other side..you change the hot to cold/visaversa
