P14224
Hey peeps,
This is gonna get involved as its a multi- issue problem.
Ive always had great help on this forum.
So bear with me for sounding a little novice here, but heres the dealio. I've got a 50 gallon heater,( NG power vent style,about 10-12 yrs old. The heater sits in the basement on one side of the house under the kitchen. The house is rather long and the longest run to the last faucet is close to 65' in length. The reason being is the 3/4" run is dropping from the top of the heater into the basement floor(5') then thru the floor 18' then up into basement shower/sink, then runs to first floor bath fixtures directly above, THEN up to second floor bath. It takes lot of time to get hot h20 to last fixture. The 3/4" copper line in the basement slab has started to leak where it comes out of the slab. I will figure out a way to snake a new line so it doesnt go down thru the slab, which will eliminate at least 10' of length. So here's where I need some advice. I also want to get hot water faster to the furthest faucet and I think I can achieve this by installing a 5 gal.elect.htr. inline roughly 25' from the fixture as a "booster". Is this an acceptable practice? I've already bought a 5 gal. htr at my plmbg. supply house (scratch and dent) for $25 so I thought this would be a cheap fix. (I can wire it myself btw)...so any and all advice would be appreciated. thanks
