welcome back, where the hell you been????
st is abbreviation for street , which is a term used to describe a fitting that is both goesonta and a goesinta fitting as opposed to just a
goesonta on both ends
goesonta=female also know as hub, coupling, sleeve,fps [female pipe size
goesinta= male, street, spigot, mps [male pipe size]
22 is short for 22 1/2 , it is a fitting just like 90 or a 45 bt is 22.5 degrees
they are called, 22, 1/16th bend, same thing, one is a fraction the other is degrees
the term 1/16th comes from cast iron fittings
as does, 1/4 bend, 1/8 bend etc...
pvc is called in degrees 90,45,22
image of a 22 and a st 22
