- Joined
- Sep 28, 2014
- Messages
- 8,578
- Reaction score
- 2,977
you can use a welding machine to thaw frozen copper pipes
It should be noted that copper, which is not a mineral but a metal, can corrode over time, while the very problem with modern plastics vis a vis waste is that it doesn't break down. The chlorine that you mentioned in drinking water is corrosive to copper as well, not to mention any acidity (pH 6.5 or below). So while the "shelf life" of copper might be high, that doesn't apply to installed copper exposed to the environment with water running through it. It depends.
copper is a mineral the actual element name of copper is CU
https://www.minerals.net/mineral/copper.aspx
