Hi everyone...
Our home (typical, late 50's, single story w/ basement, suburban boom, ranch style home) had/has a well somewhere. I am not sure where it is/was. There is a big pump in an alcove in the basement that has been disconnected from the home piping since '97 when city water came to the neighborhood, but I am not sure if the well was decommissioned because the pipes are still connected from out of the wall. The two pipes from the pump go out of the alcove towards the neighbors house which is only about 35 ft away, so likely the pipes turn and go for some distance around to the front or back yard, but there are no covers in the yard that I can find and no plumbing visible above ground.
Would the county have records?
Where where wells typically placed in the late 50's suburbans?
Can an old well be restarted and used for an lawn irrigation system?
What problems could arise?
Who is a reputable well company that would conduct an inspection for a reasonable cost? (Indianapolis)
HOUSE IS NOT TO SCALE (~20 ft from ext. wall to property line)
Red = Pump and visible pipe (in alcove in basement)
