Hi,
In process of replacing a faucet that has a crack causing water to leak. Trying to remove the faucet that I did not install so I have no idea how it was mounted nor any documentation. There is some rust and what appears to be a set screw. Trying to figure out the correct way to remove the faucet mount. Screw doesn't move, hex shaft also doesn't move. Both were sprayed with penetrating fluid. Trying to determine whether it's just the screw I need to get out or the entire hex shaft (or both). Don't want to cut it apart unless I have no other choice. Any help is greatly appreciated.
Thanks,
Jim
Thanks,
Jim
