Help with DIY PRV replacement
wtalber
Dec 25, 2024
USA
Hello. I am looking for advice, please. Homeowner in 30 year old house with Poly B piping, on city water (I know, re-pipe). We have reduced flow in our shower, and tests reveal pressure drops (from 50 PSI) at a spigot when another is opened. I believe the original Watts N35B PRV is blocked, as the water was pretty bad, sediment-wise, when we moved in (1995). From what I read, we got our money’s worth out of this PRV. Talking to local plumbers, it is popular to just do a PRV delete, for about $400. I don’t know what the city pressure is, but do not want to gamble with deleting the PRV. The local supply store even said they do not stock PRVs.
After much reading, my plan is to replace the PRV, main shut off gate valve, and outdoor spigot shut off with ball valves. I plan to use PEX-B, with the Oetiker cinch clamps. I like those, as they are also in my travel trailer.
My plan is to buy the short lengths of Sharkbite brand of PEX, made in US.
I am waiting on Watts to provide a recommended replacement model of PRV.
I have two questions:
1. Can Oetiker cinch clamps be used on the Poly B to PEX adapters, vice the crimp rings that come with them?
2. For elbow fittings - Brass vs stainless steel?
Thanks.
    922 KB
    763.5 KB
The PolyB is a larger I/S diameter & the conversion kits include the necessary ring. The pex clamping tool for the "crush" rings does work ........ but I do not know if the cinch clamps would be large enough.
All you can do is try.
Sarg,
Thanks. I have not yet looked at the ID and OD, I thought maybe someone has done this. Wanted to avoid buying both crimp/clamp tools.
Understood ...... I also have the polyB crap and convert to pex whenever I have to "fix" or alter something in our system ...... but I also have accumulated a large tool bag full of various fittings and tools ....... both cinch & crush ............. probably over a thousand dollars by now ...... because I'm always convinced bad crap happens after hours.
