Hoping someone can help me with a my drain venting system. Attached are pics of the current system which has no internal vent. When the septic was done, a vent was added OUTSIDE the home where the septic line exits the basement since there was nothing inside. I am gutting the bathroom and hoping to fix this. My question is how i should go about venting this, or should i leave it as is. Currently, the kitchen sink is 1.5" which goes into a 2 inch line. The bathroom sink, and washer stand pipe also go into this line. That goes into the main 4" line. The Shower goes directly into the 4" line, as does the toilet. I was thinking of basically keeping the existing style system, with putting the kitchen sink, bath sink, shower, and stand pipe into the 4" line individually. Then venting it by tapping into the 4" just after the toilet (or vent it before?), and running it up to the roof (like the attached pic). Would this be a correct way to wet vent the whole system? I would be ripping out all of the existing piping and replacing with new, using the correct sanitary tee's etc. I attached a pic of my layout to approximate where each drain needs to be. Everything is basically right over the septic line where it exits the house, except the kitchen sink. Any advice on how to figure this out would be appreciated. This is the one aspect of my renovation that has me very confused. I am in NJ and the code is NJ Uniform Construction code.
