I'm a retired hands-on builder and know a good bit about my well and water system, thanks to help from this forum and particularly, thanks to Valveman. I have an 800' deep well with a Gurndfos 10S10-15 two-wire pump set at around 300'. I have a 44 gallon WellX/Amtrol pressure tank. I have one of Valveman's Cycle Stop Valves on the system and a Cycle Sensor Pump Monitor.
OK.....we just had our utility power blip off and back on again 4 or 5 times in about 5 minutes. The lights dimmed, the TV went off, air fryer that was running blipped off, but all came back on again almost immediately. This cycle repeated 4-5 times during the next 5 minutes. I had just started our washing machine to run a load of clothes and the washing machine was in the process of filling when these power interruptions began. The Cycle Stop Valve had kicked in and the well pump was running continuously to fill the washing machine when these power interruptions began. I was not in the laundry room when the power interruptions were occurring. Within a minute of the last interruption, I turned on the kitchen sink faucet and there was no water. I went into the utility room with the pressure tank and the pressure on the pressure tank read ZERO psi. The pump breaker was not tripped but I flipped the pump breaker on and off and nothing. The Cycle Sensor Pump Monitor was reading 0 amps, indicating that the pump was not running. I did not know what to do next to try to figure out what the problem was. The washing machine looked like it had filled completely for the size of the load I was washing, so I'm guessing that if the pump was not running, the pressure tank drained its contents into the washing machine. Then maybe 5 minutes later, the pump came back on, the pressure tank began to fill and everything is now working properly.
QUESTION: Was it purely bad timing that I was filling the washing machine and the pump was running continuously to do (because of my Cycle Stop Valve) so when the power interruptions happened, and the sequence of power interruptions caused the pump to turn on 4 or 5 times in very short sequence, and as a result, the pump motor overheated and the built in pump thermal overload protection kicked in and prevented the pump from turning back on until it cooled off enough? And after it cooled off enough, it came back on to fill the pressure tank? If that is not what happened, I am completely mystified and would appreciate any advice as to what caused the pressure tank to drain to ZERO psi and caused the pump to not turn on.
Thanks.
Thanks.
