Help this girl finish a dishwasher install :)
natalie
Nov 22, 2015
9
Hi everyone!
Trying to replace my old Frigidaire dishwasher with a new Whirlpool.
Per the installation manual, the Whirpool requires a special elbow 3/8 x 3/4 (https://www.lowes.ca/brass-fittings/watts-a-158a-38-in-x-34-in-compression-fitting_g1200132.html) that i bought separately.
Here is where i'm running into issue, the water supply line appears to also be 3/8" in diameter...so it's the same size as the elbow connector and won't fit into it. How should I go about connecting them?
Here's a few pictures to hopefully give you a better idea..any help greatly appreciated!
http://www.picpaste.com/line_up-ehTtSG6g.jpg
http://www.picpaste.com/overview-USTDtX2H.jpg
Do i need a special adapter to get the water supply to connect into the elbow?
If anyone is able to tell just from the pictures, do I indeed have 3/8" copper pipes?
I feel so silly asking but really hope i can get this figured out :eek:
It appears you have 1/2" water line. Measure the outside dimension of the copper and it is probably 1/2". As an apparent novice DIYer it will probably be easier for you to remove the copper line entirely and replace with a braided stainless steel dishwasher water line that is available at any plumbing store. You will get this done. Good luck.
hard to tell the size of that pipe , it looks to be regular 3/8'' tubing also know as 1/4''L
are you sure the fitting you bought is not 1/4'' instead of 3/8''?
just for a visual reference, is the water line to the dishwasher the same size as the water line supplying your kitchen sink faucet?
I measured the outside circumference of the copper water line to my dishwasher and it measures ~1.7".
If I reading this table correctly, it would mean the pipe is only 1/4"?
http://cd8ba0b44a15c10065fd-24461f3...laforums.com/posts/6057/Pipe Sizing Chart.jpg
Ok, did some more reading & learning.
So I'm fairly confident my dishwasher supply line is 1/4" NPT.
I was worried because my dishwasher requires a minimum water supply line of
3/8” (outside diameter) but that is the outside diameter and I think 1/4" NPT meets that minimum?
So now I guess I'm back to figuring out how to connect this copper pipe to the dishwasher elbow, which i did confirm is 3/4" x 3/8.
that is a typical, 3/8 supply tube found under 99.99999999999% 0f american house sinks
might be 99.99998 not sure about a guy in virginia, he refused to answer the survey..:D
Hahaha, not in Virginia :)
So are you saying my supply tube is in fact ok? (that i dont' have to change it?)
and I will take a picture of the valve and post shortly :)
Thanks again!
I think your supply line is to small...thats why i keep asking for a picture of the valve and if it is the same as the kitchen faucet supply
you thought i just wanted to see in your cabinet,,,i have seen under hundred of cabinets, unless you are storing hummles i'm ok
hate hummels,,,they stare at you:D
Natalie. I recently purchased a new dishwasher and they now have a universal contraption on their dishwasher which is not common with older supply lines. I removed their new fitting and brought it to Home Depot, and was able to get a stainless steel flex dishwasher supply line which solved all the headaches.
hahha, no hummels, you can rest safe!
Attached is a picture of the valve to my dishwasher supply line:
http://www.picpaste.com/pics/imagejpeg_2-gb02o8FH.1448299320.jpg
Hopefully that's what you were looking for?
ps: How many guys have bruised ego's when informed that their supply tubing is too small?
Yeah, I'm thinking i may cut off the copper pipe a few inches after the shut-off valve, and use a compression fitting to hook-up a flex line that could then easily run to the dishwasher?
But i guess I'm just worried the pipe is now too small....
The stainless steel flex line has a rubber gasket inside of it so you would not need to use any compression fittings. Just Screw in and turn on.
