Gastronomique
Greetings Folks. I'm a DIY guy who needs to replace a couple faulty ball valves. I've never done this job. The valves are brass Legend brand, model T-1000, attached to half inch PVC pipes. The pipes are hot and cold water for my bathtub. See photos.
I'd like to buy replacement valves and have them ready to install before shutting down the water supply to minimize the amount of time without water.
I have some basic questions. Can anyone tell exactly what type of valves I should buy from the photos? They look like threaded female valves to me.
Do I also need to buy some PVC and brass couplers?
What's the right way to approach this job? Should I cut away the existing couplers down to the bear uncoupled PVC pipes?
Would Sharkbite valves work instead of threaded valves? If so would I need any couplers at all?
Thank you in advance for any replies. I need to get this done before Thanksgiving. Any help would be appreciated.
