Hi, I have pulled the valve from the wall to replace cartridge as it can only be accessed from the back. I am awaiting shipment of the cartridge. I have inserted some caps to stop the water for the moment. I have tried to put the valve back for testing, and I am struggling to line up the threads properly. The two pipes become a little pushed out to get valve in place. I am wondering if I was meant to take off the elbows and the wall connetor bits that you can see in the photos, put those on the valves and then put the whole lot back. Clealry I am a DYIer. I tried two plumbers to fix the leak which is the cartridge both said, I need to replace the whole shower as they have not seen that valve before. That's why I decided to take it off myself. Any ideas on putting it back?
To be clear, putting the valve back together is not the issue, I am fine with that, its re-attaching it to the pipes. Take elbows and the other connectors off first? Or try and squeeze it back in which I have struggled with.
